Islandlaker
Thread starter- Joined
- Jul 4, 2016
- 23
I have a question and it is probably dumb. I have a lower unit off of a 1997 Mercury 115hp Offshore edition. I do not know if it is a long or short shaft, everything I see online tells you how to measure the shaft length with the outboard completely together. Now when I measure the driveshaft itself it is 25inches exactly from where it exits the lower unit to its tip. I know a 25 inch shaft is the XL shaft, Is it that simple? I just want to be sure that the driveshaft length I got is the correct way to measure the shaft length with the lower unit separated.
