long shaft/ short shaft?
mudslinging79
ok i have a evenrude fastwin 18 horse, how can i tell if its a long shaft or a short shaft??
rickdb1boat
Re: long shaft/ short shaft?
mudslinging79
ok i measured and got 17 1/2 inches. so i take it tis a short shaft. does it make any difference what length one runs on the back of a boat??
tashasdaddy
17 1/2 is for a 15 inch transom. 22 1/2 is for a 20 inch transom. if you run the short shaft on a long shaft boat, you are not deep enough in the water to cool the motor (water Pickup) and the prop can't get proper bite.
running a long shaft on a short shaft boat is fine, except for performance, there is too much foot in the water, which causes excess drag, so you do not get the optimum speed and performance. a transom elevator, can be put on a short transom, to properly accommodate a long shaft motor. clear as mud?
mudslinging79
be like putting super swambers on a vw bug withoiut changing the rear end, youll go but not that well. answered my question oin an easy to understand way, thanks.
also if you plan on fishing in shallow or rocky water long shafts suck i have a 4horse johnson long shaft and want to convert it to a short were i use a flat bottom boat for fishing
tashasdaddy
yep, that's a good comparison.
