Long Term GPH Realization
tpenfield
When I went from a single engine sport cuddy to a twin engine day boat a few years ago, I was a bit concerned about the increased fuel usage.
I was getting about 6 GPH overall on my 24 footer and was thinking double on my 33 foot twin engine boat.
Now that I am 3 years into the 'new' boat I have taken a look at the fuel usage over the past 3 years. My stats are:
720 gallons
110 hours
Resulting in 6.5 GPH :) :) :)
I had an idea that the big boat was getting pretty good fuel mileage but did not realize it was so close to my old boat :thumb:
I am sure if my 33 footer were a cruiser versus a sport/day boat it would be a different story. Regardless, Not a bad case study for the virtues of a twin engine boat.
littlerayray
That's interesting but the 2 engines are working less than the single so it kinda makes sense
littlerayray
Had a guy question fuel consumption about my boat one day and told him if he is worried about fuel consumption then a boat may not be a good idea
QC
I would bet 17 brazillion dollars that you operate(d) the boat(s) differently. There is a missing piece of data here.... distance traveled. That would give you MPG and average MPH. Both are required for this to be evaluated completely.
Alumarine
It is important if you need to know how far you can go with a set amount of fuel.
QC
^^^^^ I always say I want to know where I am going to run out, not when ;)
tpenfield
2 hour meters on new boat = 6.5 gph per engine thus 13 gph maybe?????
No, the 6.5 gph is combined. My boating habits are substantially the same . . .cruising, tubing, etc. The only thing we do not do with the 33 is wakeboarding.
We tend to go fast with the 33 than we did with the 24 . . . maybe 5 mph faster on average as the longer hull carries better through the chop where as the 24 would tend to nose dive a bit more.
QC
Some of this, but hard to believe all, is carb vs. MPI. But I think I will sum this up as we all needs twins!!
tpenfield
The big difference with the twins that I have noticed and may be contributing to the fuel efficiency is that the boat does not fall off plane like a single tends to do in rough conditions. The twins run like the boat is on rails and just plows through everything with little/no variation in RPM or speed.
So, I can cruise across the bay in 2-3 foot chop at 2500 RPM and going 27 mph with the twins, whereas the single would be at 3K+ RPM to do the same in the 24 footer, and the speed would tend to fluctuate, so it would need a bit of throttle now and then to keep it going.
cptrick3
I once had a 10 meter Trojan(13' beam) with twin 454's. It had a 320 gal fuel tank. My current 24' Chaparral has a 74 gal tank. I think there's a reason for that.
milehighjc
This is something I have been tracking, but have no reference points. My Crownline 182 with a 5.7L 2bbl carburated is running an aggregate of 3.3 GPH with a range from 3.13 to 4.06. The boat is pretty heavy, and Im typically running with 4-5 adults + gear, beer, and food. Not surprisingly, there is a strong correlation between High GPH and a high level of water sports. I have NO idea if that is running well or not - sometimes it seems to me like it is it is running a little rich, but Im never sure.
And yep, I do keep a log. Insane I know, but Im a data guy.
littlerayray
Yes but I also follow the one third rule and on long trips like from cornwall to kingston I do the half rule once I'm at half I start looking for a fuel stop but I always follow the one third rule
dingbat
The big difference with the twins that I have noticed and may be contributing to the fuel efficiency is that boat does not fall off plane like a single tends to do in rough conditions. The twins run like the boat is on rails and just plows through everything with little/no variation in RPM or speed.
Little to nothing to do with twins. Everything to do with the increased displacement. A single inboard diesel with equalize the torque would probably be even better
QC
Two engines with double the weight and double the displacement (same each) fixes what? Diesels are always better on fuel if all else is equal.
