long trip
paulspaddle
Next week I'm going to pick up my boat I just purchased. I will be towing it approximately 800 miles. The boat shop checked it out, greased and claims trailer is in very good condition.
With that said, are there some tools you wouldn't leave without for a first time long distance tow?
Also, this time of year I could run into poor weather and hence salted roads. Would you concern yourself with protecting the outdrive? How?
1990 Glastron Sierra 175 with 4.3L on a single axel 'Knight' trailer.
Thanks!
cc350
Re: long trip
Spare tire, Jack, hand tools; what tools you'd need to pull and replace wheel bearings. Grease gun and grease/wheel bearing grease(Marine type)
cc350
Re: long trip
If roadsalt is incountered on trip just stop and wash off before taking it to it's winter nest.
cc350
Re: long trip
Also every couple hundred miles pull over check trailer wheels, pull on tires to check for wheel bearing play. Pulling over and checking will help cool down the bearings. Better safe than sorry on a trailer you don't know the history of it as to how well the maintenance was done.;)
rbh
Re: long trip
And just remember to tie it down good, both bow and stern.
as well if the trailer has electric brakes, and on ice covered roads the should be, remember to feather/adjust for the conditions, the last thing you want is for the trailers wheels to lock up and skid into another lane.
jfadool
Re: long trip
When I purchased my Whaler I am so glad that I had a buddy of mine with me. An extra sent of hands and eyes is a great thing to have.
We also had a full assortment of hand tools, straps, flashlight, spare fuses(for the truck), and a jack and stands. We used all of them in our 300 mile drive.
good luck with the new boat!
BF
Re: long trip
Hey Paul...
Glad to hear the trip planning is underway... I'd take some tie downs and a couple lengths of chain and quick links... In case the tie downs on the rig are either not there, or no good... and in case there is no chain from the trailer to the bow eye, or maybe no safety chains on the trailer.
Does the trailer have a spare? If not, I'd take one with me or buy one down there. As others have said, bottle jack, good tire iron, grease... flashlight, tub of waterless hand cleaner, some scraps of wood to use for blocking if needed. A hunk of 4x4 and some tie downs can get you moving again if you break a trailer spring. (have done that one more than once)
As for the outdrive, it will probably need to be tilted all the way up for clearance... you might want to put a tie down around it and secure it to either the tube pulling hardware, or a stern eye so that it doesn't move around side to side... It seems one's with power steering are less inclined to move around on their own.... But.. when I first got my boat I used a tie down around the LU to the tube-pulling hardware... in case there was a run down of the tilt/trim while driving.... I thought it would be lousy to get home and find the drive had slowly sunk and ground on the pavement.
I have used a big plasticy gunnie sack thing around the lower unit wrapped with bungies when I've towed things before, but I'm usually thinking more about stone chips from gravel (or to keep mice/critters out of LU for over-winter storage). I guess something like that would keep the salt off too.
You might also consider doing some research of either garages/trailer/bearing supply places on your route (and enter in your cell phone)... in case you break a spring or bearing or something and need to find help/parts.
Also, you probably already know this, but stop and feel the hubs for heat buildup after a few miles, again after 30 min's or so, and then anytime you stop for gas/snacks etc.
A word or warning... when I last bought a boat trailer, the guy said he had "just repacked" the bearings himself and they were good to go.... I used it for one trip, they didn't heat up, but then I had some time so I decided to inspect them.... Previous owner had applied 1 dab of grease to the outside bearing (obviously had not removed the nut, just pushed a little grease around, mostly onto, the washer).... outer bearing itself still had mostly old grease in it.. the inner bearings were not quite dry, but almost.... They had not received grease/attention in a long time and felt worn. I'd wager the previous owner did not know there was another set of bearings behind the hub. So, I replaced all the bearings and added bearing buddies. The shop you bought from probably did a better job, but I myself don't usually feel good about trailer bearings until I've done them myself... I've seen even experienced people apply an amazingly small amount of grease (rather than really pack the bearing and fill the hub). Depending how paranoid you are, it might be worth 15 min to jack up a wheel, feel for play, and then pop the dust cover off to see how much (or little) grease there is on the outers...
Last thing that's handy to bring is spouse and/or kids... gives you more "duty free" allowance at the border.
Good luck! Drop me a note when you get back.
paulspaddle
Re: long trip
tire iron...check
jacks.......check
flashlight..check
safety kit...check
grease.....check
sunflower seeds...check
spare tire....check
blocks of wood...check
wrench kits....check
chain and carabiners....check
extra fuses....check
straps.......check
bungee cords...check
random assortment of hand tools....check
friend or family to go along.....darn!
Come along Brent....I think there's a bottle of single malt at the border with your name on it. :D
I'll look for some heavy plastic around home. I'll probably just carefully wash it on my return.
I love my son and wife, but I'm secretly looking forward to spending 4 whole days by myself! (this isn't the message I'm sending my family) I think the last time I've spent that much time alone was when I was driving truck nearly 10 years ago.
eli_lilly
Re: long trip
Check the tire pressure and inflate to maximum sidewall rating.
-E
Bifflefan
Re: long trip
I guess there will be a little alone time as that trip is about 16 hours for a trucker. Cant blame you tho, its nice to drive a little and see the sites.
BF
Re: long trip
Would be fun... but life's a bit too busy right now to take the time! :) When I picked up my boat, I left the family in Fargo for the day, and spent about 7 hours driving (alone) to get the boat back to Fargo... not a bad day... beats walking the malls.
Hmmm. single malt... what a good idea. Gonna go pour a couple fingers worth.
See ya!
roscoe
Re: long trip
I always have a spare trailer light, and some wire, tape, and wire strippers, shrink tube, and lighter. And a few spare bulbs.
You are gonna need them some day, so you might as well carry them along.
marlboro180
Re: long trip
On longer trips , I tend to bring an IR temperature gun to shoot temps on tires and hubs ( in addition to some of the above mentioned items.
Glad to hear your picking her up !
paulspaddle
Re: long trip
Thanks.
I plan to be in Lake Geneva, Tuesday at around 1PM.
Al Kungel
Re: long trip
For longer trips I always carry a spare hub. They are not very expensive. Above all do not speed, especially when pulling a new to you trailer and boat. Good luck.
paulspaddle
Re: long trip
agreed, if it doesn't have a spare, I'll get one on route.
I have no problems keeping the speed down. It is actually is a pet peeve of mine to see people driving 70+ mph with a trailer or motorhome....there is a lot of wasted energy and wear and tear at those speeds.
