Look at this carb combination
greens1098
Ok I know I have another thread going. I fixed that problem but now I have a new one. Ok when I had first bought the boat here is the combo of carbs I had. Both upper throttle plates are stamped with 339570 and 340838. The lower plates are both 40947. 4 of the 6 carbs are 436883 and the other two are 436883.
The new set of carbs and throttle bodies I got are upper throttle bodies are both 340837. The two bottoms are 340946. All six carbs are 436882. This is on a 1999 Johnson 200. What setup should I be running for optimal performance on this looper?
greens1098
Re: Look at this carb combination
Bump...
