1991 Mercruiser 454, carbureted, mechanical fuel pump.
This is my fuel pump, it died in January. The sandy looking stuff turned to dust when I rubbed it between my fingers.
I replaced the pump and the fuel filter, but there seems to be an lack of fuel flow, had to bump up the idle to get it to run, then under load, it started surging and backfiring thru the carb. I checked the fuel pickup and anti siphon valve, all clear. I also siphoned out several gallons of gas to see if there was sediment, nothing.
I'm guessing some of the crud in the picture went into the carburetor. Any chance gumout or something similar can clean it out? I tried some already and it still backfired a bit when I hit the throttle, but this was just running it on the hose, not under load. I just rebuilt the carb last year and I'm not excited about doing it again...
Any ideas?
Thanks!
