Re: look what me and my brother towed home!!!!!
Well we were back at it again this weekend, during the week i got the 8 leaky rivets we had drilled out and relaced with nyloc nuts and bolts, and it passed the final leak test. We got transom cut out and test fitted in hull, will probably get to permanently installing it next weekend. Went back and forth with the idea of coating it in epoxy or not, and decided against it, boat will be stored in doors year round. I have no intensions of selling this boat, so if it needs to be done again in 10-15 years so be it, transoms in these tin cans are a piece of cake compared to a glass boat. I figured the original transom( i think it was original) lasted 30 years, well 20, it should have been done ten years ago, so i should be good for awhile.
[/IMG]
[/IMG]
Next on the list was the floor, we got all pieces cut out and fitted, have to get the tank in yet before we can rivet it down.
[/IMG]
No, we did not cut the piece that will cover the tank to narrow, the bulkhead and braces that go between between stringers to hold the tank down are not in yet to pull the stringers together, so the center stringers are bowed out some.
[/IMG]
[/IMG]
Had to see how many decoy barrels we could fit up on the front deck. Plan on putting a hinged door on the floor of the front deck, (over the area that was the isle in the islander cuddy) for a large under deck storage, will be plenty of room for all kinds of stuff under there. We cut floor piece to for the bottom of the storage area so everything is not bouncing around on the hull itself
