Scott06
- Joined
- Apr 20, 2014
- 7,560
Easiest swap if you had 3.7 originally is. 4.3 as the drive ratio is the same
Would recommend you try and find a donor boat that if it doesn't have a working engine has all the dressings to swap over like the alternator, ps pump, engine mounts , water pump, intake, wiring harness, and ignition and fuel systems.
Generally a truck engine can work but none of the accessories above will swap over. You need a manual transmission flywheel to work with a Merc coupler
Buying the engine first then coming back and getting all these pieces will cost a fortune, unless you find a roached boat with all these parts on it
