Looking for 15hp Johnson carb for my 9.9
Charlesjoker
From what I have read about the 76 Johnson 9.9 motor I just was given and got running, I just need a carb from around a 1975 to 80 15hp to bring it to a 15. I missed one on ebay, EDIT Thanks Randy Haughton,La
tashasdaddy
Re: Looking for 15hp Johnson carb for my 9.9
why? no one has actually proven that changing the carbs, make a 9.9 a 15 hp. no actual, published data, just a bunch of claims.
14ftgrumman
A sure-fire way to make the 9.9 into a 15 is to sell the 9.9 and buy a 15.
A lot less work and a lot less money and proven results.
ezeke
Try sea-way.com in Seattle.
bktheking
This subject has been beaten to death LOL, some guys say the 15 carb makes the motor rev higher and idle like crap, I don't see how 5 hp can be squeezed out of a motor by changing a carb but hey if it works why not.
ezeke
The specifications sheets for the 15HP rate them 1000 RPM higher than the 9.9HP. That's a specification, not a guess.
You might want to read LeeRoy Wisner's article on this subject, specifically the section entitled "Difference between the 9.9 & 15hp", foundwithin this link:
http://www.sschapterpsa.com/ramblings/Johnson 9.9_15.htm
ChrisAG
Rather than being incredulous that a carb change can generate an additional 5hp, think of the OMC 15hp model as the blueprint engine, with the 9.9 the restricted model. I'm sure it is easy to chop 5hp by giving an engine a carb with a narrow venturi.
I agree that the subject has been done to death, and it is probably easier to buy a used 15... but from 1974-78 the only difference was the carburetor.
mnmx3
I would think there would be SOME increase in RPM with the carb swap. Whether or not it is 5hp, I couldn't say. Sounds logical to me - Nascar uses restrictor plates (smaller openings) to limit HP. From what I understand the 15 HP carb has larger throat and would allow potentially more air/fuel....
bktheking
What TD is saying, has anyone dynoed a 9.9 with a 15 carb to prove it becomes a 15 hp. I have studied the differences in the early years and it was just the "carb". Then OMC started adding tuned exhaust, I think it was then that a true 15 was created. How could a manufacturer brand a 15 a 15 when the design was changed years later, wouldn't a tuned exhaust add a hp or 2?
cajuncook1
One of our forum members did an excellent job of explain the similarities and differences. Cheers!!
ChrisAG ChrisAG
Default Re: Difference between a 9.9hp and 15hp Johnson?
The search function on this site isn't very good. It seems you need more than three characters per word, so just entering "9.9 15" will return zilch. Entering "Johnson 15" will return everything with "Johnson" but the "15" will be ignored. However, entering "15hp" will return results, but any posts that might have contained "15 hp" (space between) will not show up.
However, I'll give you some info on the differences:
Standard propellers are the same for both 9.9 and 15 thrughout the 1974-92 lifecycle of these engines, 9.5"x10"
1974-78: No difference except for the carburetor. Both motors share a square exhaust tube that seals with the gearcase, creating a "wall of water" from spilloff accumulation in the midsection that helps silence the motor. The water overflow exits through the top exhaust relief ports. Exhaust gas exits through the prop.
Note: One of the 1977 OMC brochures (Johnson or Evinrude) claimed an "increase in top speed" for the 15 starting that year, but I don't know of any additional difference from the 9.9 that accomplished this. The claim was definitely made before the spacers were added in 1979 (see below). My best guess is the carburetor bore was made even larger on the 15 starting in 1977, but perhaps someone else could confirm this.
1979+: spacers added at intake reeds on the 15 to improve throttle response.
1981-84: 15 now has tuned exhaust (shorter, rounder tube) to increase torque. This results in more mixing of the exhaust and exiting cooling water. Little (if any) water exits through the top of the midsection's exhaust relief port. Some believe this made the 15 louder. There were also changes to compression ratio & timing (according to 1981 OMC brochures). 15's full-throttle operating range increases by 500 rpm over pre-1981 model. All these changes apparently gave a true 15hp measurement at the prop instead of the flywheel (OMC may have been prompted to do this due to increased market competition, and possibly because some felt the 15 wasn't a huge enough power leap from the 9.9).
1985: 15 has exhaust tube reshaped again, squarish but still short.
1990: 9.9 now shares same short, square exhaust tube with 15.
In various years there were changes that affected both motors at the same time, such as a powerhead redesign that placed the thermostat at the top, and a push-pull throttle cable instead of the metal twist linkage.
ezeke
Just about all of the OMC motors were re-rated in the 1980's - that how 140 crossflows became 115's with no actual changes.
bktheking
The reed spacers don't even count as a "power adder" just helped throttle response , they were used in 15 hp "SAIL" motors until 84 when they became mainstream in both motors.
Gotta love re-rating, kinda like going from rear wheel to crank, Ford was famous for this on the 5.0L mustangs 225 HP, not at the wheels!!!
jmendoza
Something that escapes most people who have trouble with the 9.9 being able to produce 15 horse power is revealed by very close scrutiny of the manufactures specifications.
It is impossible to design an engine to deliver exactly 9.9 hp, so what they do is rev the engine until it produces 9.9hp and take that RPM and publish it as the rated output. Actually the engine can rev above this point and produce significantly more than the 9.9 rated hp.
If you look at the rated HP RPM of the 9.9, it is far lower than the maximum full throttle RPM, and if you extrapolate that you will find that at it's full throttle RPM rating, the 9.9 is putting out about 12 HP. The 15 puts out about 18 HP at it's full throttle rating. This will vary a little because all engines are not exactly equall due to manufactuirng tolerances.
My 1975 9.9, converted over with a 15 carby revs out to 7460 RPM on a 9-1/4 x 8 prop. That is almost 500 rpm over the rated maximum, and it loves it.
The above information I want to thank John Gill of Holloways Marina for, as he explained all of this to me back in 1978 when I first began inquiring about these engines for my 12 foot fishing boat. At that time, John had recently completed his OMC Master Certification on this then new series of engines and had all the inside scoop on them from the OMC school he attended back east. Seeing as Holloways had a fleet of over 30 rental boats with these engines, he was a specialist and expert on them, and still is for that matter. Most, if not all of my knowledge on the 9.9/15 series comes from an intimate association with John, as every year I visit him on the weekends at the local marina and see all these engines taken apart, or being serviced. He loves to show me all the weird problems he has found and discuss any issues I have with my 9.9. I have seen virtually every model of the 9.9 made in pieces at his shop over the last 36 years, and this has been a very unique and special oportunity for me, plus the bone yard out back is a treasure trove if you have a 9.9/15.
Incidentally, there are a couple different conbustion chamber variations, one has a weird wedge shape near the plug to help stop fouling at trolling speeds, intersting huh? Synching the plugs also helps, try it: Face the end of the negative electrode of the plug towards the exhaust port. Use BR7-HS plugs, they work great.
BTW, Chris's outline above of the differances is accurate to a T and I have seen each of these variations first hand. Most perplexing is that eventually OMC went back to the old square exhaust tube on both the 9.9 and 15, as obviously it was not that critical.
More revealing is what the APBA guys have found when using these engines (15ss) for hydros and tunnels in Class J (junior) racing. All they do is add a restrictor plate between the carb and manifold to keep these engines under 10 HP, which tells you they put out more than 10 HP in stock form.
Most air cooled 2-stroke cycle engines of 200cc displacement (the 9.9/15 are 216cc) easily put out 25 HP, and liquid cooled 125s can easily approach 35 HP, so it becomes apparent that the 9.9/15 is quite restricted and capable of allot more power. For goodness sake, my old 1970 McCulloch 101 (125cc) puts out 18 HP on gasoline, and it's a single cylinder air cooled engine. Thus there is no question about the power potential, it's there. The reason the ratings are so low is for longevity, a restricted carb allows full throttle operation all day, without over stressing the engine. All outboards are always down on hp compared to auto and car engines of the same dissplacment for longevity reasons.
bktheking
Thanks for that Jmendoza, interesting read.
OptsyEagle
On the 1975, OMC used different throttle cams as well between the 9.9Hp and the 15Hp, telling me that when you change the carb. you may need a different spark advance.
jmendoza
You know, I just looked at my old 9.9 carb, and if you have a lathe it could just be bored out to convert it, we do this to Kart and Motorcycle carbs all the time for more power. Then you would have to put in the 15 jets and go have fun.
I found this all out by asking one single question of John back in 1978: How do they design an engine to make exactly 9.9 HP? I found out the answer is they don't, it's actually got more power and they rate it at less than full throttle to comply with restrictions on engines over 10 HP. He pointed out that nobody made a 10 anymore (at that time) due to new regulations for boats with engines exceeding 10hp.
I also remember when the Japs tried to get a leg up on OMC and Merc by advertizing propeller horsepower versus crankshaft horse power in the early 1980s..but their engines were more expensive and heavier, and did not resist salt water very well. Plus, they never established a good dealership network.
You know many guys go buy transom brackets and cowls off of 9.9 engines so they can operate their 15 on federally regulated waterways and avoid detection by the rangers. The other trick is to just upgrade the 9.9 with the 15 carb on early years because it is externally identical.
I should point out I did the conversion because my fishing grounds at Big Bear Lake are at 6800 ft of elevation, and the boat had trouble planning with a third person on board. Initially I went to the next size smaller prop, which helped a little, but when I complained to John that it was still not enough power, he suggested I buy the 15 carb, and that did the trick. This will kill some of you: It was $78.00 back then.
I seriousley doubt that OMC , given it's reputation, would ever over rate any of their engines. In fact the oposite is true, and quite common amoungst outboard manufacturers, and that is to under rate them. It is well known that Karl Keikhaeffer of Mercury would take a 10 and rate it at 7.5 so it would out perform other manufacturers 7.5s, making the Mercs appear to be more powerful for their rated HP. A quick check of dissplacement however would reveal the Merc to be a bigger engine.
ChrisAG
Just to expand a bit on my posted info on the exhaust tube, the third version for the 15 (1985+) was adopted by the 9.9 in 1990, so for the last three years of production both models shared the exhaust tube.
This is not to be confused with the first (long) exhaust tube that sealed with the lower unit, but is rather an entirely new part number that is a revised "tuned" exhaust for the 15 (and the first tuned exhaust for the 9.9). With all the market competition and power ratings at the prop firmly established, I would think this third and final exhaust design did not reduce the power boost the 15 had gotten from the earlier tuned exhaust in 1981.
Given this same short tube was eventually used in the 9.9, it implies that for the last few years of its production run the 9.9 was given a slight power increase (though this is not proven).
