Looking for a 1 - 1.5 - 2 gallon gas tank.
roscoe
Anyone have a line on a small gas tank for an outboard.<br />I want it for my kicker motor, which will run for 8+ hours on a gallon of gas. Looking to save space and weight in my 16' boat.
JB
Re: Looking for a 1 - 1.5 - 2 gallon gas tank.
Don't think I ever saw one smaller than 3 gallons, Roscoe.<br /><br />I suppose one could be made with some hardware from a conventional tank and a very sturdy 1-2 gallon container.<br /><br />Good luck. :)
roscoe
Your probably right JB.<br />I was going to tie it into my main (built-in) tank, but don't want to have to be turning the diverter valve every time I fire up the big engine.<br /><br />Besides, a couple years ago SLOOPY told me not to. :) <br />( incase I have a fuel issue, it would effect both motors )<br /><br />I did see a small motor once, that had a tank that hung below the cowling, on the outside of the boat.<br /><br />And Scepter makes one that hangs on the inside of the transom. But it is 23" wide (too wide) and is 2.5 gallon.<br /><br />Hmmmm, I think someone should make a 1.5 gallon tank with a 4 oz, measuring cup built into the cap. It sure would save a lot of space in small 10-14' boats, and would hold enough gas for a days use with a 4-10 hp motor.
