still afloat
- Joined
- Aug 5, 2011
- 19
Hi all!
I found this forum searching on the internet for Starcraft boats and had to join.
I've been wanting to find a decent Starchief for some time, but every one I've looked at so far has been battered and abused. I want one that's new enough to have flat windows, I prefer not to deal with the older wrap around plastic windows, I don't want any boat with prior damage or hull repairs, I don't want anything that's been shortened, lengthened, or converted from an I/O drive. It must be an outboard version.
I don't mind a project but I don't care to do any welding or riveting and I don't want anything that's been in saltwater or all corroded. (I had a 1996 Starcraft that turned out to be corroded down the keel and around all the transom rivets).
I've looked at about 20 or so boats over the past few months and all were pretty worse for the wear. One even had all of it's rivets coated in what appeared to be body filler, another was full of water and nearly collapsing over it's own trailer, another looked to have been hit by a bus and hammered back into shape.
I looked at another last weekend that had been bent so bad that the hull was curved to the left, the left gunwale was bent, the cabin was removed and on the ground, and the bow was dented in about a foot on the port side. Amazingly the seller made no mention to any of this in his ad.
I have a motor here, a great running Evinrude 110, which has very low hours on it, so I figure that an 18' boat would be best. I'm not far from Philadelphia, so it needs to be within a reasonable distance away from here too, I figure about a 100 mile radius give or take.
Not having owned one of these before, is there anything I should look out for?
I realize that I'm most likely looking for a 30 to 40 year old boat and things like wood and paint are most likely going to need to be replaced but are there any other issues with this model?
I ask this because two that I've looked at had cracks along the spray rail area towards the front of the boat. Those boats were pretty beat up but the fact that I saw two with the same damage concerned me a bit.
What should I expect to pay or what would be a fair deal for a good solid restore-able boat?
I have a trailer too. If putting one of these on a roller trailer is OK?
