RiffeShooter
Thread starter- Joined
- Feb 27, 2013
- 33
First of all I am new here so hello!:thumb: I just purchased a Bayliner Trophy 2502 with a 300 hour AQAD41A motor in it and a duo prop outdrive. I've taken it out a couple of times now and she runs excellent. I now want to do all of the "make my mind safe" maintenance such as fluid changes, filter changes, etc. The fuel and oil seem to be straight forward as I am no stranger to engines but the outdrive is a new beast to me.
First of all, I am not sure which one I have (tag on top worn out) but I do know it is either a 280, 290, or 290A, and obviously a Duo Prop, hopefully someone here can tell me. The props on it are the A6 series. Here is a couple of pics:
Second - There appears to be some small leaks and some water intrusion since the oil is milky. Is there an "easy" place where I can find the part numbers I need to order? :facepalm: Here are pics with what I think are 3 separate leaks:
Third - I think I read somewhere 2.7 quarts is the ticket. Should I go with a 75/90 synthetic gear oil like Amsoil or do these drives like something different?
Fourth - Which paint should I use on this one and where do I get it?
Finally, with regards to the props, does someone make a stainless set for this drive? All I have seen are aluminum.
Thanks again for any help, I do appreciate it!!!
Jason
Jason
