Looking for a repair/service manual for a 1983 Evinrude 70HP
boobie
Re: Looking for a repair/service manual for a 1983 Evinrude 70HP
You can get the factory OEM service manual right here in I-Boats. Stay away from Seloc or Clymer.
boobie
Then try Ken Cook.com in Milwaukee WI.
boobie
You want a manual specific for your motor. Those other ones try and cover to much and don't get down to detail.
vt700guy
Looks like Ken Cook may have one for $80.
boobie
That would be money well spent if you plan on keeping the motor. You can always sell it when you're done with it.
emdsapmgr
That ebay manual looks to be a factory one. Appears it's the real deal. Or get it from this website: outboardbook.com Ken Cook makes all the factory Johnson/Evinrude manuals
vt700guy
Are they basically the same motor in 81' and 83'? I know a lot of motors (i.e. cr250 Honda) didn't really change a lot for several years. Figure if I can get a good manual and save $60 I'm all for that :)
brim_buster
I have PDF manuals on alot of motors that I share on here for free. The one I have for Evin and Johnson only goes to 35 Hp :)
vt700guy
You had me excited there for a second :lol:
81 and 83 are esentially the same motor, so same manual will do.
emdsapmgr
If your engine has power trim: the major difference between the two years is the power trim unit. The trim electrical systems are different. The 81 uses a 3 wire motor, the 83 uses the newer two wire motor. Their electrical trim control box internals are different, too. (the 83 has two relays inside.) The 83 uses the newer "plug-in" ignition coils, a minor difference. Some of the plug ends on the ignition system may be different. However, if you can get the manual at a good price, it should cover everything close enough to make it worth your $.
Painterx
I have a ken cook if your still interested
