Re: Looking for advice
Sea'n Red, good morning, first you must thank your friend for looking up to you and your experence (sp) and knowledge. I have driven and handled boats from 8' dinks to 60 ft motor yachts, power and sail. Whenever I was teaching someone how to drive a boat in the Coast Guard I always told them that the slower you go, the more control you have. See if you can take a day and just do dock landings (or as we called it in the coast guard, dock crashing). Have someone with a roving fender and pull a few feet away, then bring her in. Pull out a few more feet then do it again. Once you feel comfortable with that, pull the boat away then do a circle and do it again. If you feel comfortable with a 27', it will be a short time before you will have no problem with a large boat. Like what was said above, you will have a much larger sail area that will be affected from wind. Also, the draft will be affected by current alot more, but in a shorter time than you will think you will be able to control it from your past! Pay much attention of your draft and heigth if you are anywhere near any low bridges. Good luck with it and don't make it more that what it is, it's just a little bigger boat.<br />DO NOT use the steering wheel to manuver the boat to and from the dock or pier. I'm sure this boat has counter roation screws, if you haven't used them before, you will find that this boat will be easier to dock than you think. The hardest task will be trying not to use the steering wheel to contol the boat. Good luck and calm seas.<br />Weedy
