Lou C
- Joined
- Nov 10, 2002
- 14,537
OMCs had both one piece (1985-1990) and two piece manifolds/elbows (1991-1998) on the 4.3 V-6s. In fact the 2 piece is easy to find because Volvo used OMC designed parts when they went to the SX series drives in 1994 and on up. So you can replace those cracked manifolds/elbows with Volvo Penta 2 piece V6 manifolds, or even the aftermarket equivalent of them which are widely available here in the USA. I did just that, replacing my OMC one piece units with Barr aftermarket exhaust on my '88 4.3.
What you seem to have there is the pre-vortec style of the 4.3, with the roller cam no balance shaft and one piece rear seal. 1987/88 up to about '94 or so when they added the balance shaft. You can pin it down better by looking up the casting #s on block (rear right hand side pad) and casting numbers on the cyl head, which are on the inside surface near where the rocker arms mount.
https://www.rapidomarine.com/default...ngines262.aspx
look here for information on casting #s and variations. Mine is the same vintage 1988.
