Looking for correct impeller
dellsboater
I have a 1988 Cobra, not king, 5.7 looking for impeller kit. Seem to find two out there, one with 6 blades, one with more. Also would like to get complete kit or what ever I need to replace.
Thanks
Nivekt
Re: Looking for correct impeller
Thanks
The original OMC part number is 983895. The corresponding GLM part no. is 89950 and Sierra part no. 18-3058. The correct impeller kit is here: Water Pump Impeller Repair Kit for OMC Sterndrive Cobra 984461, GLM 12091 - Sierra 18-3212-1 - iboats
Howard Sterndrive
and the OEM full kit is
0984461 WATER PUMP REPAIR KIT 1 $58.30
available from any Evinrude dealer
dellsboater
Some I see have the black housing, some do not. Is that part usually need to be replaced? It looks like it may be hard to find if you do not get it in the kit.
HT32BSX115
Hey,
Hows that Lib running?
You probably don't have to replace the housing every time you replace the impeller if you're not injesting a LOT of sand or it gets run dry.
Can't remember if it's a plastic housing or not but if it is and it gets run dry, it wouldn't last long.....
(I seem to remember the SS impeller housing getting hot inside it's plastic outer housing?)
Regards,
Rick
dellsboater
It runs great, love this boat.
Here is one kit I found.
