Re: Looking for expert prop advice
The cavitation plate should be even with or up to 2" above the bottom of the boat. Sometimes higher. Each bolt mount hole equals 3/4" raise and will result in approximately 100 to 150 RPM increase. How high you can go with your motor height really depends on the prop.
Originally you were looking at stainless props and now you're considering a Hustler? Don't waste your time, it's not as good a prop as the Black Max you have now. If you haven't raised your motor, you should consider going up one or two holes. That should provide the hole shot and top speed you are seeking.
If you switch to stainless, you need to look carefully at the various designs. Some stainless props loose thier effective performance after 5500 or so RPM. But they'll have great hole shot. Other have good high RPM performance at the cost of hole shot.
Sorry to inform you K.P but the Turning Point Hustler prop that I purchased is way better than the stock Black Max that came with my boat! (I purchased the same size diameter and pitch, 13.25 X 19P)
I reached my max rpm of 6000 and the Black Max would only reach 5700-5800rpm max, I gained 2mph on my speedo, my cavitation in the turns is way less, and my holeshot has increased considerbly! I would highly recommend this prop to anyone!
I will never know if the Stiletto prop would have better but with these results I don't see how? I have completely forget about about a SS, especially considering the price difference of approximately $300.00 dollars. I am a true believer in Turning Point props now........Irv964
