Looking for good waterprrof switch
Fleetwin
I'm looking for a source for a good (quality) water proof switch.
I need a SPDT (Single Pole Double Throw) On-off-On Momentary.
The application will be to add a trim/tilt swich to the transom area to lift the outdrive (Volvo Penta SX) while outside the boat. The V-P uses a three wire system much like OMC did (Red=Power, Green=Down, Blue=Up)
I may buy two and install one in the bowrider area to use while fishing.
I would prefer a rocker type but a paddle would be OK. Surface mount preferred, I want to drill as small a hole as possible.
Ideas/Sources?
Thanks.
Re: Looking for good waterprrof switch
Ayuh,..... How 'bout a toggle switch, 'n silicone cover,...
Fleetwin
Bondo,
Is that on e here on iboats?
That would work. But, are the internal components Brass?
sam am I
Mercury New Remote Control Trim Tilt Switch 87 18286A43 | eBay
On a more high tech side.......
Could also install a RF controlled unit and use a remote control and drill no holes.........I have RF remotes for my lectric downriggers, makes fishing with with other folks a whole lot easier if I can just sit back and run the downriggers up or down and not get hooked by staying waaaaaaay out of their way. Could certainly run a motor trim/tilt as well..........
Bondo,
Ayuh,.... I use 'em on our equipment fleet,... No complaints yet, most in damp to wet conditions,...
Click Quote on my post above to see where they come from, it's in the picture url,...
jc55
sam am I, tell me more about these RF remotes...
sam am I
Sure...
The receivers are just small'ish 2 channel RF/address encoded 8-bit high-speed CMOS(gassssp) uPC(Microchip)relay controllers' on a PCB that hook to 12V for power. The relay's parallel the local switches as a bypass if needed/wanted.
The transmitters/remote's are just coin battery powered and have two buttons, A and B.........Press button A to go up, let go, it stops.....Press button B to go down, let go, it stops.
Just internet junk I changed up a bit to fit my lazy butt, kokanee fishing can get busy w downriggers.
Fleetwin
Sure...
Thanks All. Sam I Am, do you have an example of that remote switch. I am intrigued!
sam am I
Yup.....this is what I have, mine has always worked great.
How to control linear motor by simple 2ch rf remote control? - DnaTube.com - Scientific Video and Animation Site
2CH DC Wireless Remote Control Momentary On Off Switch [0020022 (S2M-DC06/09/12/24 & C-2)] - US $28.00 : RF Control System, RF Remote Control Switch Online shop
12V 2CH Wireless Remote Control Switch Relay Waterproof Controls | eBay
They're all over the net in various forms, prices and quality I'm sure, just make sure it's 2 channel (up and down relays) and can go into "momentary" mode and the relays can handle the current you need..........GL
Oh and if I may suggest with a main motor control..........I definitely would install a DPDT switch on the dash to be able to "switch out" the RF units up/down signals that wire into the boat's common up/down circuitry!! You know, if it goes haywire?...You don't want some stray signal from someone opening a garage door or flying a NSA drone over you keeping you safe from yourself raising your motor up while you're at mock speed.:facepalm:
I like these lil locker types for something like this.....
http://www.chiefaircraft.com/alco-mtl206n.html
http://www.vetco.net/catalog/product_info.php?products_id=12154
bruceb58
Do yourself a huge favor and go with something simple like this:
TRANSOM TRIM SWITCH - Marpac TTC-1-MP - iboats
or do a search for
volvo 3855650
which is what I put on my boat
The Volvo ones are a bit pricey but I found a new one on ebay for a lot less that list price.
Both of these switches are waterproof and designed exactly for where you want to put them.
Fleetwin
THANKS All. Lot's to think about.
I'll post what I decide to do.
