After seeing replies to my thread regarding my carbs spitting fuel and one carb needing gas to be sprayed into it for the motor to run better (http://forums.iboats.com/johnson-ev...tting-fuel-please-advise-possible-596867.html) I have decided it's time to inspect the reeds on this thin even though I am feeling it's over my head.
I would bring it to a shop BUT no shop around here says they will work on it because it's so old so I need to tackle this on my own...and can only do it with help from others like you
Can someone give me the basic steps I will be looking at doing for this project AND any Do's/ Don'ts that I may be unaware of. Thank you much.
My guess is this...
1. Remove carbs
2. Remove intake
3. Check reeds for ???
- Do I clean them, check for cracks, check gaps etc.?
IF nothing visible then put everything back on?
4. Replace gasket to intake
5. Replace carbs
6. Test motor
Also what about other causes of spitting fuel or no gas getting to carbs?
Blocked hoses, check valves etc.?
The carbs were rebuilt recently and the problem did not go away.
I am worried there is multiple issues which really makes it hard for a newbie like myself to figure out.
The thing under the flywheel (trigger base?) was all gummed up when I got it as well which would cause problems I am sure...I am pulling the flywheel off soon to inspect that area but do not think it has anything to do with the fuel issue...but if I am wrong please tell me.
Thank you much.
My guess is this...
1. Remove carbs
2. Remove intake
5. Replace carbs
6. Test motor
Thank you much.
