Looking for parts...71 45hp Chrysler long shaft
SSSuper83
Looking for parts by serial number for my old barn find. Lower unit seal kit, etc. All the websites (including this one) dont have a listing for a 71 45 hp...its either 40 or 35 hp. My serial number is 459HA, and it has the Aquadart gearcase. I know a lot of these engines are fairly interchangeable parts wise, but I would like to be sure before ordering something I am not going to be able to use.
Thanks!
Frank Acampora
If it has the Hydro-Dart or "stump stabber" gearcase it is quite possible that someone has substituted an earlier lower unit because by 71 I am relatively certain they all had the bullet shaped gearcase without a point. AND, The stump stabber gearcase is not swappable on the later model lower unit because it uses a special gasket at the split and the pinion gear and bearing is larger.
The good news is that the propeller bearing gland seal is the same O ring. The prop shaft seal is the same and the shift rod real is the same part for all engines up until Mercury started putting their lower units on the engine--around 92-94 So, You can make a gearcase seal yourself, but do use the correct thickness because this does set the gear lash. The other seals can be ordered from almost any force 50 engine
