Looking for steering arm replacement thread or help.
mattkenton
I have a bad steering arm assembly and i heard rumor that there was a thread on replacing one. Anyone have it bookmarked? I couldn't find it through the search.
Daviet
Re: Looking for steering arm replacement thread or help.
It looks like it's time to invest in a manual.:D
boobie
Agree with the manual. You'll have to pull the p/h and more to to repair it.
mattkenton
I read a couple posts where guys were able to pull it with out removing the power head.
boobie
I believe you're right but then the mtr will have to be removed from the boat to get the steering shaft out of the pivot hsg.
mattkenton
That's what I heard
Haffiman
1: You need to remove the gear case to get rid of the shift rod going through.
2: You need to remove the lower rubbermount holding the bracket to the leg.
3: You will need quite some HEAT to get the screws loose, which probably may ruin the upper mount,which again means removing the powerhead to change.
4: You need a hoist to hold the powerhead and leg if you manage to get the screws loose.
Bottom line, probably bigger job than changing pistons!!
boobie
Matt, the advice above is right on.
