Looking for the best way to wet sand prior to clear coat?
Hi all, I am looking for the best way(direction, technique, etc. . . to wet sand before my clear coats start going on.. Already have 4 coats of both colors on and have been using 600 to knock it down in between coats. . still has a tiny bit of orange peel, but the 600 has been great so far. . any help would be appreciated. .
ZenBasser
Re: Looking for the best way to wet sand prior to clear coat?
Some paints are not made to be wet sanded. Assuming yours isn't one of them, sand in one direction -- not crosshatch like you would with primer or filler.<br /><br />Wet sand step by step through grits up to 1500 depending on how much of a show quality finish you want.<br /><br />Buy quality paper,keep it wet,and don't let the paper get clogged with debris.<br /><br />Good luck.
John Boelte
Also, try keeping some dishsoap on hand, put a drop or two down when you start sanding; it'll keep the paper from sticking.
