Looking for the directions on adding a tell tail
Hoyt79
Where is the directions for adding a tell tail, pee'er or whatever you want to call it.
Hoyt79
Re: Looking for the directions on adding a tell tail
Thanks man!
Hoyt79
I looked up those part numbers and it shows that its a plastic looking elbow? Is that right? I would think it would need to be metal...can someone tell me exactly what size elbow I am looking for and that I can tell them in Ace hardware that I need?
Daviet
The factory part is plastic, works just fine. I think the last time I bought one it was 1/8" pipe thread that goes into the block with a 1/8" nipple.
iwombat
Use the plastic. Bronze will cause electrolysis with the aluminum in the block.
D
DJ
Guest
Plastic is fine. I agree on the different metals causing electrolysis.
If you boat ONLY in fresh water, may be not a big deal.....BUT.
Hoyt79
Ok, thanks guys! It just threw a flag on the play in my mind when I saw plastic being fitted into metal...so I can just walk into Ace Hardware and ask for 1/8" pipe thread and 1/8" nipple?
