Looking to read and scale a 4 to 20ma and various DC sig outputs through a laptop?
Limited-Time
I'm looking for software/hardware that will allow me to read and scale various signal outputs (see below)through a windows based PC. Anyone have experience with this??
4 to 20ma
1 to 10VDC
1-5VDC
.5 to 4.5VDC
Limited-Time
Re: Looking to read and scale a 4 to 20ma and varioud DC sig outputs through a laptop
Thanks, both seem possible. However I did not see the 4 to 20mA option on the first unit. And the PLC programing is not something I've tinkered with in the past. I was hoping for a more "plug and play" type solution.
oldjeep
If it is a desktop pc then just google Data Acquisition Board. Its been almost 20 years since I was in the industry, but there are plenty of devices capable of doing what you are trying to do.
bruceb58
Not sure what(type of hardware) you are measuring but typically you would read the voltage drop across a shunt. Granted, 4mA is pretty darn small to be measuring across a shunt.
I just did a quicky search and posted that one to see if I was in the ballpark for you.
I have a meter that can read and simulate the 4-20ma and another that can do 0-5v they can be bought used on ebay for about $50 each or new for $800-1200 each :laugh:.
I also have a plc5 allen Bradley rack that has plug in cards to do the readings into the plc which only cost $50 used (including 12 cards) but they software to program the rack is very expensive if you buy a registered copy
bigdee
I'd just get yourself a little PLC and its associated software. If you want something new try: AutomationDirect.com - The best way to buy industrial controls - low prices, fast shipping and superior service.
Otherwise I'd just get an older unit off ebay
A simple process controller from there will allow you you to look at any of those inputs. What units of measurement are you trying to scale?
Limited-Time
Re: Looking to read and scale a 4 to 20ma and various DC sig outputs through a laptop
Both pressure and temp transducers. The scale can be anywhere from between 0 to 100 psi to 0 to 5000 psi and temp 0 to 300 deg f,
you can just use converters and bring all the signal's in on 4-20ma then scale them back to what ever unit you are using. Industrial junk is cheap especially used so all you require is a way to bring 4-20ma signals in to your pc.
bigdee
gm280
When I was in the business we used tons of UE-9 LabJacks for most everything. I can't remember any signal we couldn't digitize through it. And we used them everywhere as well. Maybe you could find one used on EBay.... Just a thought...
