looking to replace current prop
ghettogord
Hi i'm looking for a new prop for my 60 hp johnson its between 1980-85, it's on a 14 ft fiberglass sangstercraft runabout which is about 1500lbs, I don't know the make of the current prop i have but it is a 12-1/4 x 15 3 blade aluminum. I don't know the rpm at WOT but i get to around 25-27mph when at WOT. It will mainly be for cruising pulling a tube and some fishing. Thanks for any help.
usskydvr
Re: looking to replace current prop
Your current prop is in the ballpark. The only way to optimize is to know the max RPM you can run with a normal load.
