Looper or cross flow ? 90 degree v4 or 60 degree v4
dodgedakota459
Model # xe112sledr serl.# g03987822 I need to know exactly what I have trying to get the motor running ... took the carbs out they r very clean new plugs 30 gap & tried a hotter .. fresh gas, fully charged battery ,,, changed the main fuse on top of motor 20 amp was blown... all wires seem fine.. checked the spark against the block has blue with burnt orange jump .... I looked up the Model # xe112sledr this motor is a 1996 60 degree motor wich has a different electrical system than many other Evinrude motors .... is this correct on the 60 degree part ??? is this a looper or a cross flow ??? thanks for every ones help Howard ....
trendsetter240
Re: Looper or cross flow ? 90 degree v4 or 60 degree v4
I think the 112 is a 90 degree crossflow. Easy enough to tell though, the looper will have 4 single throat carbs, the crossflow will have 2 dual throat carbs.
boobie
You've got a cross flow. All the 112 hp's were.
emdsapmgr
You can view the exploded factory parts assembly diagrams by model number from the fatory (Bombardier) website: epc.brp.com
kenmyfam
+1 on the cross flow.
