loose exhaust tube leaking water into bildge
Status
Not open for further replies.
1216bandit
A while back I had water a leak into the bilge and after close inspection of the bellows which were in top shape I had no idea what else to check. I brought it into the local shop and the mechanic said that of the 4 nuts on the exhaust tube , three were finger tight and the 4th he couldnt get too without removing the engine. After he snugged them up the boat (1984 starcraft islander) was watertight. I am starting to take on a bit of water again and would like to recheck the exhaust tube nuts, but I really dont know where to look or what to feel for. Is it just a simple matter of following the exhaust to where it runs through the transom? Special tools needed? Can the nuts be replaced with nylocks? Any tips appreciated! The engine is a 1984 mercruiser 130 with alpha 1 drive. Thanx...Dan
Re: loose exhaust tube leaking water into bildge
Ayuh,... Right where the tube meets the transom there are 4 Bolts, 12point Bolts,...
No Nuts,+ you'll need a 12 point 3/8" socket...
1216bandit
Thanx!! Will I have enough room to remove the bolts and put a bit of loctite on the threads or do things have to be taken apart to pull them out?
Ayuh,.. I'm surprised they can be reached at All...
Status
