Looses power at WOT
parrisw
Ensign
Ok, just put the boat in the water today, its been sitting all winter. Last year it ran great, and last year I put on a new carb. During winter storage, the fuel was run out of the carb, this year, I put in a new impeller in the leg. Then today put it in the water, idled around a little bit to make sure no overheating and that the water pump was working ok, all seemed ok, so throttled up, cruised for a few minutes at 2500rpm, it was fine, then I throttled up to WOT ran great at about 3500rpm for a couple minutes, then all of a sudden just started loosing power?? I back out of it and it ran fine, tried to throttle up more again, and it wouldn't run up?? So we just tied it up for now, to wait for better weather, was pretty lumpy out. The boat is 1977 I think, its a OMC stearn drive, with Ford 302 engine. Like I said, new carb last year, previous year, we put in electronic ignition. I'm thinking its maybe loosing fuel?? Maybe choke plate is sucking closed??? Just looking for some idea's to check when I go back out.
Re: Looses power at WOT
Ayuh,... Change the Fuel Filters...
towman818181
yep fuel filter what gas are you running it on last years????????
parrisw
Ensign
Ya, I suppose we should just do filters just because. Its funny though, that it ran up ok for a min, then powered out?? Gas is 89 octane from the fuel dock, that's all they got.
towman818181
you can always go to the stickies and read the fuel trouble shooting thread it really helps thanks guys for putting it there;)
parrisw
Ensign
Yes, I did read through that. Thanks for that!!! I've got a nice gauge. Just need to get some clear tubing for testing!!
parrisw
Ensign
Replaced the fuel filter today, seems allot better, had a couple hiccups, but after a 10 mins of running it seemed to smooth out fine.
