jafishingfool
Thread starter- Joined
- Jun 7, 2005
- 5
My 1997 115hp Johnson oceanrunner has problems with shutting down during idle. also runs like its spitting and sputtering.and only runs up to 4200rpms. When idleing it just shuts off and i have to crank it in high idle position. No problems with primer bulb going flat. Cylinders are functioning properly when you remove the spark plug wires and when I plug off carb air inlet they flood out. The idle problem happens intermittenly. The spitting sputtering happens a lot. I have ran all the bad gas out and have ran OMC cleaner and tune up thru it and am going to run sea foam thru it today.
