Re: Losing Power/ Fuel Delivery 1968 18 HP Evinrude
Not necassariy.
Depends on how much water is entering. It can still burn the fuel, but at a different rate of the other cylinder. A lot of hotrodders used to pour water down the carb while the engine was running to clean the carbon off the pistons, valves, etc. The reason I asked was because one spark plug looked much cleaner than the other. Top of that piston (which ever cylinder it was in) may look the same. Doesn't have to be much water to screw up the performance, but it will still burn as it is getting fire to the plug which you KNOW now is happening.
Then again it may not be this at all.
