marty5030
- Joined
- Aug 9, 2006
- 31
I have a 1990 Evinrude 150. It was running fine about 3/4 to 7/8 throttle and then started to slow down. No noises or rough running was associated with this loss of power. I tried to give it more gas but no response. I put it in neutral and it died. I could restart it, but only if I had 3/4 throttle and it would idle about 1500 to 2000 rpm. if I put it in neutral it died. I could not get it in gear because it would die too quickly. I had to be towed back to the dock (thank you friendly fellow fisherman!)
I checked the gas tank (over 15 gallons), the oil reservoir (over 2/3 full) the spark plugs for all 6 cylinders looked the same (no carbon build up or metal).
Any other ideas?
Thanks in advance,
Marty
Any other ideas?
Thanks in advance,
Marty
