Loss of power
Chuck07
Need some help on a 2007 Hurricane FD231. I have lost power to the ignition switch, gauges and trim button on the gear shift. All other power is good, batteries are hot, not corroded. Any ideas would be appreciated.
Chuck07
Have checked all fuses and wire connections. Still no power.
Howdy
Would be kind of helpful if we knew what motor you have. The boat type doesn't matter with this issue.
Check the 90 amp fuse on top the starter terminal, if its there
Sorry but I have no idea with that brand. Will notify the Mod to see if maybe they move it to the outboard section
