Re: Loss of W.O.T. RPM..or, get up and go is gone...further advice needed.
When I began this project there was good (I thought so) fuel flow from the tank to the motor, now it’s plugged solid. Something is blocking the pickup tube in the tank and will have to be dealt with sooner or later, so now is a good time. I believe my no start issue is because of the no fuel from tank problem and perhaps the lack of performance thing will be solved (for me) at the same time. I would like to know how and where the tank fitting is before I start this phase of repair. If I knew about the tank fitting, there is the possibility I could cut through the floor, access the fitting and then fiberglass the cut piece back. The way everything else has been on this boat, there could be all most anything in that fuel tank. If anyone has knowledge of a 1994 Four Winns Fling fuel tank and would like to share, Please do.
Wish me good luck and I will wish you favorable winds
Jim
