Loss Power - 1994 Johnson 225 Ocean Runner does not run over 1300 rpm's
CoastalPete
Hi, hoping someone can help me with my Johnson 1994 Ocean Runner power problem. Just put the boat in slip after 1st installing new plugs, new fuel/water seperator, new inline fuel filter, decarbed engine and filled up tank 110gal. (had about 20 gal. from last season but was stablized). Put it in water and ran low rpm's no problem, then went for test run and no power over 1300rpm's? Took it to slip, runs fine in idle and will rev up past 5000 RPM's with no load, although after she runs for awhile I do hear something not right when doing so, like a real suttle miss fire (but no banging, knocking, smoke, etc.). The RPM's also will not stay consistent, it will rev up and down a bit on its own? I also hear some clicking on the side of the fuel pump. I am not getting any engine alarms, except when I first started it up this season the alarm stayed on steady until I shut it off then never heard it again.
Thought maybe gas problem so added more fuel enzymes (Startron) and checked fuel water seperator for water and there was none. Had marina mechanic hook up seperate tank to motor same problem, so its not gas in tank. They also confirmed spark on all 6 cylinders. I also checked enginer wires at night and found no arcs. Also, the water coming out of the engine felt warm but not hot where I should be overly concerned it has something to do with running too hot and the engine's saftey system (SLOW, which I think keeps the boat RPM's under 2200 or so).
Thinking maybe its the VRO fuel pump (hoping nothing to do with power head), need to confirm this, any easy way to check, what is the clicking sound an air leak? If so, should I rebuild, replace with VRO2 or new type OMS (I never had a problem with fuel or oil before this). PLEASE HELP point me in the right direction!
Thanks,
Pete
robaloroger
Re: Loss Power - 1994 Johnson 225 Ocean Runner does not run over 1300 rpm's
maybe need carbs cleaned.. if you pump primer ball and power increases then it is the fuel pump. I did read on a thread that you should hear a click from the pump and there was a way to determine if the vro was no good by the click increasing or not increasing(not too sure) Make sure you check the prop shaft incase fishing line is wrapped up in there. good luck
