Lost Forward & Reverse after hitting rock
sltwtr007
Hey Folks,
I recently had the unfortunate experience of hitting a rock causing damage to the prop and lower unit. After the hitting the hazard I cut the engine and trimmed the drive all the way up to find the prop hit pretty bad. I turned the engine over again, trimmed down and was able to drive the boat back to the launch as if it didn't happen. Back at the launch I trimmed up and the prop/lower unit made a noise like I hit something else (but didn't) and from that point on could not engage Forward or Reverse.
Repairs shops said it would take at least 3 weeks before they can take a look so I'd like to attempt to repair on my own. I've considered buying a used lower unit and new shift cable as thats what other folks have suggested I try.
Any feedback is appreciated. Thanks, Brian.
QC
Re: Lost Forward & Reverse after hitting rock
Hey sltwtr, welcome aboard! I saw your other thread and you are in the right place now. Since others will not find that I suggest you post up some identifying info for the drive/engine combo. Also, you should take a look in the Adults Only section ^^^^ for links to service Manuals etc. Good luck!!
zbnutcase
Hey Folks,
What drive package?
Bt Doctur
broken lower driveshaft, pinion gear split, pinion gear broken off driveshaft
Ayuh,... Drain the outdrive,+ look for Metal...
sltwtr007
Thanks for the input, I will drain the outdrive and follow up on the metal.
Bt Doctur - broken lower driveshaft, pinion gear split, pinion gear broken off driveshaft..>> The boat could actually run if any of these things are the problem? After contact I was still able to drive back to shore and everything seemed fine. This possible?
Thanks again guys.
