Lost key so what igniton key do i need?
fishfeatures
i can't find my boat key anywhere, despite a big peice of cork attached to it...
I had a look at the ignition and i can see 375 stamped on it. can someone tell me what key i need to look for to suit please
71Windsor
Re: Lost key so what igniton key do i need?
A little background info would help. Year of the engine and hp would be a good start so we know what style remote you have.
fishfeatures
1986 70hp evinrude is the motor, remote is just like this one pretty much, except no kill switch
crb478
check on line for a 375 key, they typically run around $10.00
emdsapmgr
If you lose both keys and it is an OMC control box with an OMC key switch inside, all is not lost. When the key switch is made by OMC, the key number is stamped on the side of the barrel of the key switch. Usually on the flat side of the threaded part of the barrel. It's usually not visible unless you separate the two halves of the control box and look on the switch barrel. It's usually a 2 digit number. OMC keys are made only by the factory. There are maybe 30 key number combinations which are stocked by many dealers. Take the key number from the barrel and give it to an Evinrude dealer.
fishfeatures
I did take apart the remote control box, and the numbers 375 are stamped on the barrel. I can't find anything on line in regards to that number.
The dealer over here, charges a absolute fortune for anything OMC, that's why i'm turning to you guys on here. Surely i can find a spare out there somewhere?
boobie
Has the dlr got it and how much does he want in US $$$$ ??
Joe Reeves
Right where the key is inserted.... look closely as the key number is imprinted right there. What is that number?
fishfeatures
Joe, I can't see anything there at all, all that I can see is 375 further down the barrell.
fishfeatures
He is saying he can't replace it and is trying to flog me a whole new ignition.
Joe Reeves
Strange, The key number has always been there... very small print though. Perhaps you have a very late new ignition switch and Bombardier has changed their number ing setup. I'm thinking from the 1970's up thru 1991 when I retired.
fishfeatures
I'll try and get a magnifying glass and see if that throws up something. I'll be back...
Joe Reeves
Usually it's a two digit number. I have a couple hundred keys (3 types) dating from day one to sometime in the 1990's
71Windsor
I had to replace my ign switch last year mine is the same as what you have in your picture I went right to west marine and picked one up it was right out on the shelf. If my memory serves I only paid about 20$ for it. It was not expensive at all. The tricky part is getting the wires on the new switch for me it was a pain in the rear! But it wasn't that bad to replace.
emdsapmgr
The pre-made factory keys for that vintage box came consecutively numbered 51 to 67. Look for those numbers.
71Windsor
You calling my box vintage!? My old lady takes offense to that
Lol
fishfeatures
there is definitely no markings right where the key slots in. I'll bite the bullet and fork out for a new ignition.
thanks though gents for the help
