Lost key
merc75
I lost my keys to my 1975 mercury 850 85hp. locksmith could not do no blanks it is double sided too old any suggestions? i do have numbers off of switch 126 B51045
gm280
Re: Lost key
You could check with an authorized Mercury dealer OR replace the entire ignition switch with another switch... JMHO!
oldman570
Re: Lost key
A Merc Dealer should be able to get a key for the switch. I believe that Merc only used less than 6 keys for the control switch's.
JMO
Oldman57
Fun Times
Re: Lost key
(126) B51045
Here should be your Merc OEM Ignition Key part # 30431126, KEY @2 (MARKED 126)
Googled the number for you to pick a place to order it from online or walk into a local dealer and have them order you one up.
https://www.google.com/search?q= M...+30431126&rls=com.microsoft:en-US:MIE-Address
If anyone is interested, If the key numbers are provided like it is here then for future help of how to find what key is needed, here is the bulletin to help out with that.
http://www.google.com/url?sa=t&rct=...koGYAQ&usg=AFQjCNH0BCe6dVHAK8ys0dwtoJ8j3jMR7g
MichaelV
Re: Lost key
Where did you find those numbers that tell which key to get? I see that you said 'off the switch' but I can't seem to find them on mine and I am without a key as well for my Mercury 900 Outboard. Are those numbers on the outboard or on the MerControl unit? Any help would be great. I am not trying to hijack the thread but I found what Fun Times posted very useful and obviously the OP found the numbers. Thanks.
MichaelV
Re: Lost key
Nevermind, took apart the MerControl Unit and found the number as clear as can be.
