maddog2
- Joined
- Apr 24, 2009
- 94
I had removed the rotted floor from my 1992 Celebrity190 last Spring. I had to unbolt the power trim motor from the floor while it was being gutted. The next day, the lower unit was on the ground and the floor was covered in fluid from the power trim. I assume that the hose had busted from under the engine near the transom plate.
I don't know if it was the connection or a split in the hose. I can't see the connection on the transom plate due to it being behind the engine.
Do I have to remove the engine to repair this busted hose or fitting????
The motor is a 1992 Mercruiser 4.3L with an Alpha One Gen.2 outdrive.
