Chet labrozzi
Thread starter- Joined
- Jul 31, 2011
- 60
Hello Guys,
This rookie needs some help and advice once again. I have a 1998 238 deck boat, first time winterizing this boat, I now realize I pumped on board water tank to empty prior to putting in the antifreeze..Here is my problem, I pumped all the water out of the tank untill the pump was pumping air and squirting. The next day I dumped in 4 gallons of antifreeze and now the pump wont prime to flush and fill the lines. I tried dumping antifreeze back down the sink line, that failed. I tried hooking up a shop vac and blowing air into the tank while holding the vent closed, that failed. I tried squeezing the fill line hundreds of times to act like a primer, that failed. I tried to remove the hose from the inlet to the pump off the tank but of course it's froze to the tank and really hard to reach, felt like something was going to break so i retightned the clamp and gave up....
What can I do to regain the prime short of tearing into this major project? Has this ever happened to you before? Lost for ideas.
Thanks,
Chet
Thanks,
Chet
