lost
killerev
I have a 82 evinrude 70 hp.carbs has been reworked.rebuilt fuel pump and also have cleaned the gas tank.it is sucking bubble shut after its ran awhile.i have checked vent they are clean.does any one have any ideas what could be making it do this.
HighTrim
Re: lost
Im a bit confused as to what "bubble" you are referring to?
The fuel primer bulb?
Is this a built in fuel tank? Did you check the anti syphon valve?
killerev
Re: lost
yes it is a built in tank.yes the fuel primer bulb.dont know what anti syphon valve is
patrick4266
Re: lost
I think he is referring to his "bulb" sounds like he needs to vent the tank.
jtexas
Re: lost
If it's sucking the bubble shut, then you have an obstruction upstream of the bulb, or else the tank vent is closed or blocked, or else the bulb itself might be faulty.
If your boat has a built-in tank, it might have an anti-siphon valve, usually located where the fuel line meets the tank. When an inboard engine's fuel inlet is below the fuel level in the tank, and a leak develops (carb float valve for example), fuel will siphon out of the tank and flood the engine compartment and you won't realize it till the bilge pump kicks on, or you try to start the motor, or otherwise generate a spark.......
But, the anti-siphon serves no useful purpose with an outboard, as the motor end of the hose can never be below the tank -- siphoning is a physical impossiblity, as it would violate the law of gravity. You can take it out & throw it away.
Since you've ruled out all the other possibilities, you probably need a new bulb.
