Lost
jort15
I am working on getting my 86 Rinker Fish and ski ready and have lots of misc questions mostly going to be about seat repair and construction, but I have a question about my gas hose. The one that goes from the hole in the back of the boat to my tank, seems to be a 4in or so rubber type hose...anyway its dry rotted and cracked...where do I begin to find a replacement...I live in central Indiana...I'm also not sure where to post this, so if its the wrong forum please tell me where to repost...thanks in advance for the help I've heard this site is full of very intelligent and helpful people
jort15
Re: Lost
I think the hose says something about U.S. Coast Guard approved
ken51k
Re: Lost
That is a 1 1/2 inch hose. It has to be Coast Guard approved and meet SAE J1527 Type A2 and ISO 7840 Type A2 standards. Any local marina should have it or be able to get it for you. Do a google search for marine supply stores near you.
JoLin
Re: Lost
That's your tank fill hose. You need to use CG-approved hose, and you buy it by the foot from a marine supplier. If the fill hose is shot, chances are the vent hose is too. That's typically a 5/8" CG approved hose that runs from the top of the tank to a vent fitting on the side of the hull up near the gunwale. That hose is just as important as it 1. releieves tank pressure, and 2. leads gasoline fumes out of the tank and off the boat. If it's cracked/rotted, those fumes just gravitate to the bilge.
jort15
Re: Lost
Thank you JoLin that's what I meant by people are great to help even with issues you didn't know you had...lol...anyone have a contact for trim jobber I hear he's a good source for vinyl.
Fun Times
Re: Lost
Also bear in mind that all the items you may need are available here at iboats.com.;):)
fuel fill hose - iboats
Good luck.:)
Frank Acampora
Re: Lost
Don't get sticker shock. That hose is about 20 bucks a foot. Tyr to get it as close as possible to the original length hose. Do not buy extra thinking you will cut it. It has a piano wire reinforcing and grounding spiral insert sandwiched between rubber layers.
jort15
Re: Lost
20 a ft...wow...and I assume buying used is not advised...and at that price I'm not buying any extra...lol..I'm using old couches for foam and support to make seats...
