Lots of ?'s about johnson 5hp.
4.0l sahara
Re: Lots of ?'s about johnson 5hp.
I can't find the seal kit for The 1966 5hp only a 5.5hp what seal kit do I need?:confused: Also what size shear pin do I need for the prop.
HighTrim
try laingsoutboards.com, they are good for the older stuff, good luck ~!
4.0l sahara
It looks like the 7.5hp is what I need is this right?
tmcalavy
Reach out and touch laingsoutboards or Engine, Blade & Prop. They can tell you for sure.
4.0l sahara
Well I emailed them last week they didn't reply so I tried again they still didn't reply. So nobody knows what will fit this motor?
Thanks for all the help so far.:D
F_R
Let's face it, yours is not a real common motor. When you start asking questions about shaft size and stuff like that, you stump us. And not many of us can run out to the shop and measure one. The 5hp was a price leader motor sold to compete with the Eskas and Clintons of the day, offering OMC quality at a low price. But people still bought the Cheapo Eskas and Clintons. If they recognized quality they bought the Evinrude/Johnson 6hp motors.
4.0l sahara
Well do you know if it shares the same lu as any other model? I was starting to think this was a rarer model.:(
4.0l sahara
Thanks I got the prop I need it's in the mail. I'll look at that web site.:D
:p
4.0l sahara
:DI got the broken bolt drilled and tapped got all new bolts too. What ratio should this motor be run at. Non of the people have replied to my email about parts.:(
4.0l sahara
Okay so I'm going to order just the impeller because the lu doesn't leak and I don't know what lu seal kit I need. So nobody knows if a seal kit for a different motor will fit?:confused:
thanks.:D
