Loud Rattle On Startup
Jack2048
All,
I have a Yamaha '03 Fx140. 250 hours.
Had the Jet pump bearing and inner bearings replaced last year.
On startup, for the first five seconds, or so, the engine surges a bit and there is a very load rattle/grinding noise. Then it all settles down to normal reduction gear noise, engine noise, smooth idle.
Thoughts?
PS: a couple of trips coming up I wanted to go on, now not so sure.
Arghhh...
Jack2048
All,
On startup, for the first five seconds, or so, the engine surges a bit and there is a very loud rattle/grinding noise. Then it all settles down to normal reduction gear noise, engine noise, smooth idle.
Thoughts?
Arghhh...
Scott06
All,
Thoughts?
Arghhh...
is the starter gear retracting or getting hung up?
Any rocks or debris in the pump or trapped in the nozzle?
