I have a Mercruiser 7.4 MPI with Bravo 3 prop on a Maxum 2800. All fluid levels are fine, stern drive just serviced with no problems. Above 2000 RPM, engine develops a loud squeel. Squeel continues until 4000 rpm then you cant hear it anymore (whether because of other engine noise or not unsure). I do not get the squeel if i put the engine in neutral and rev up above 2000 rpm, only under load.
Belt was replaced and then tightened. Spun everything with belt off and seemed free, no play noted in alternator. Squeel was there last summer but seems worse now. Any ideas?
If alternator, why doesnt it squeel even in neutral? Why only when engine is in gear?
