Louisiana
Louisiana
I have a 1995 Evinrude Intruder. Last weekend, I was pulling it out of the water and my up trim would not work. The down trim was fine and I didn't hear anything when I pushed the up button. When I got home a few hours later, It would buzz as normal when I pushed it but it would not lift the motor. I changed the Up relay and still nothing. Does anyone have a suggestion? I want to keep fishing and the Marine dealers are backed up for months.
HighTrim
Re: Louisiana
Welcome to iboats.
Did you check the fluid level to ensure it is full and bleed the system of air?
Louisiana
Re: Louisiana
Thank's for the advise Chris, No, I didn't, I thought because the switch was not making a sound at first, It may be an electrical issue. I'll check the fluids.
vdimenna
Re: Louisiana
Did you try bypassing the switch? I had the same problem a few years ago and it ended up being the switch on the engine. It wouldn't click/buzz or anything when I tried to put the engine down. Up would work fine.
