Love, Necessity and Pride
Status
Not open for further replies.
Trooper82
Re: Love, Necessity and Pride
Very nice progress GT, looking good, real good!
GT1000000
hey GT with all that nice sunny weather, heat you should be done with the inside of that rig already. I think your turning into a dairy farmer...... ;)
I do like milk!;)
I figured I might turn this into a retirement plan...:eek:
Thanks, I'm tryin...:)
ezmobee
Your carpentry work is looking real good.
GT1000000
Thank EZ...
Quick update...
Got all Seven Stringers 95% cut/fit...
Tomorrow, Ill be modifying my WOG Clamps to use for clamping the transom plates...
Hopefully next week or two, I will actually start some 'glassin!
May the Force be with you all and may your weekend progress be GRRRRRRR-8!
Later,
GT1M
Trooper82
I see it coming together for you GT.
Bet it feels, in your words..... GRRRRRRR-8!
sphelps
Hey GT I think if you try hard you just may find some more room for a couple more rows of stringers!:rolleyes:
I did,nt realize there was that many it should be good and strong!
Decker83
Hey GT,
Your looking good with all the wood.
Great job.
jbcurt00
Looks fab, just like your weather:D but just to be clear:mad:
Have a good'n:)
ezmobee
Man that hull will have some serious lateral strength. You should hang a GIANT outboard on there when you're done :p
GT1000000
Yes, it actually does...
Actually had two more original stringers, sort of, along the outer most strakes, but I think those are gonna be PB with some matting over them...by the time I get bulkheads and and all the superstructure built, they definitely won't be needed...
Decker83 said:
Hey GT,
Great job.
Thanks, I keep trying...
Have a good'n:)
Thanks, jbc-double ought, yep, the weather kinda had me on edge, cause it has been lookin like rain, and I definitely don't want any of this stuff splashed, just yet...so it's been, take out the wood, bring the wood back inside...and repeat...
I am actually getting pretty good at manuevering 15 foot planks through the house, around corners, while avoiding light fixtures, fish aquariums, objects'd'art, etc., etc...
Woodonglass said:
Very Nice Craftsmanship!
Thank you, Sir!
Thanks, ez... Yeah I figured maybe someday I'll hit the boat lotto and come across a nice 250 or 300 horse...gee, I guess I better add a couple more knee braces and a 200 gallon fuel tank, also...oh well, so much for that extra live well I was planning...:rolleyes:
jbcurt00
Have a good'n:)
After you quoted me, I wanted to be clear that ^^^ was about the weather not the progress. The stringers turned out great. You should hold a class on building the support jig to elevate & align them. Killer looking setup.
Hey what is the @12X36 pc laying flat under the stringers in front of the transom? Hidden 200gal belly tank?
Have a good super sunday
psst, hey Gt: here are the next lotto #'s: 2, 28, 15, 67, 47. Don't tell nobody else.:facepalm: Ez & I'd really like to see ya hang a 300 horse off the back of anything, maybe not this rig, unless you get a running start at launch & recovery
Woodonglass
Question, is that the original stringer layout or have you added to it? Any idea as to the weight of the stringers and bulkheads that are in the boat?
GT1000000
Well the correct answer is...wait for it,...
Yes and no, sort of, well kinda...
It actually had 9, but they were cut down in a weird way and they seem to have been only 1/2 inch rotwood, er I mean, plywood...
Here is a couple of old before pics...if you count from the outermost, quasi-stringers...there were nine...
The weight is not too much of a concern, because I am sort of going to be substituting some of my own design for the superstructure, and actually staying somewhere near the original weight...I think...kinda hard to tell at this point, but as I progress, one of my todo's is to take the empty trailer to the local weigh station, then calculate how much the assembled engine weighs, deduct that from my original registration weigh in where I took the entire rig the first time, then when I get the hull mostly back in shape go and have it weighed with just the trailer...then figure how close I am to the actual purchase weight of the hull...does any of that make sense???
The extra outer stringers/fillers, as I said earlier did not do much as far as strength, so I am going to be substituting them with PB and matting...
The new, yet to be designed and built bulkheads, will also substitute a lot of cap weight down lower and probably end up trimming a few pounds and adding rigidity to the entire hull.
But again, I am not a Naval Engineer, nor do I portray one on TV, and everything I think I am going to do, may change between now and then...
That's my story and I'm sticking to it...:p
No problemo jb, I would never take anything you or anybody on this forum would say, the wrong way... I too, sometimes can inhale to much poly fumes and say things that I don't mean to say the wrong way unintentionally or the right way intentionallly or anyway whatsoever anytime, whenever, ....what were we talking about???:confused:
The two long flat pieces along the bottom were originally installed by the manufacturer, and my best guess is they were there to add some structural rigidity to the part of the hull that takes the most pounding when at full throttle/plane.
So, I decided to re-install them and make them a little longer than original...they also will provide a good place to screw the bilge pump and float switch without fear of punching through the hull...might even add an extra little plate for each when the time comes...haven't crossed that bridge, yet.
They might also add the needed strength for the 200 gallon underwater slung fuel reservoir...hmmm...
You too, have a Great Super Sunday...
The support jig just sort of came to me in a blinding flash of momentary clarity and inspiration...took alot out of me, I don't think I could go through that again...LOL
Oh and thanks for the winning lotto #'s...I am off to the local 7-11 to play them...:rolleyes:...heck, if I win the jackpot I might just redesign the transom on this thing and throw a 572 C.I. with a blower, I/O...I'll just scare the fish outa the water and collect them from the banks...hehehehe...
L8r,
GT1M
Woodonglass
All I can Say is "What a Tank". If you are using pour in foam, It will do a Lot of "supporting" for the deck so the outer stringers are really not that important IMHO.
GT1000000
Yeah, I kinda figured I might as well overbuild, or at least build it a little better than the manufacturer did...that way it can handle any use and abuse it might get in the future, plus even before I started this resto, the boat felt really solid, even with all the rot, so I am hoping that it should feel like a Brick s*%t house when I'm done...:)
rrumba
Ensign
seeing those pics comprared to the ones with the stringers going in is quite the difference. you are doing an excellent job and there will be some serious strength there that is for sure. keep it up
craigweaver
Nice Progress GT1M, whatever you're sniffin keep it up! I'll catch up soon.
Monterey Dreams
GT1M,
Just wanted to catch up with your progress, I?ve been a little busy with my own little pain in the arse. Wow, your Brick s*%t house looks great:D?..I wish I could glass that well, if you go to my thread and look in the far starboard corner of the latest photos with the steering wheel in it you should see my latest attempt. (To seal the cabin up) Ugh. I really hate FG.
c-ya
Dave:D
GT1000000
As always, Thanks for the visits and encouragement, guys... Most Appreciated...
Well while I was worried about it raining on me all weekend and didn't want to risk getting my raw plywood wet, I did not get much accomplished...
The only thing I did was drill the new holes in my WOG clamps, to get them ready to function as transom clamps when the time comes...
Oh yeah, and yay Giants, I 'spose...:rolleyes:
And wouldn't you know it, its time to go to work, and now it starts raining...good! I hope it is gone by the weekend...
Later all,
GT1M
Status
