GT1000000
Thread starter- Joined
- Jul 13, 2011
- 4,916
Re: Love, Necessity and Pride
Thanks Decker,
Sure was a lot of work to get that piece in, but in the end I am very happy with the finished product...
Cleaned up my BB today in preparation for a little more glassing, it still felt kinda stiff, so I broke out the torch and torched it...no really I torched it, turns out it had a plastic bushing inside that held the roller in place and now it is melted away...:facepalm:...Oh well, I was gonna get another one any way...I'll keep this one as a reminder of all the things NOT to do with it...
Anyhoooo, Did a little grinding of the previously PB'd holes in the transom, plus a little extra all around grinding of nibs and nubs here and there...
And, got a couple more pieces wet out with resin on both sides and one layer of CSM on what will be the bottom of the pieces...
Hopefully tomorrow I'll PB them in...one itsy bitsy step closer...
You will see where they go when I get them in place tomorrow...
Happy Monday and Good EEEEEEvening!
Your transom looks great. There is alot of work going into that little peice of wood. (LOL)
I do like to use the roller after i wet out the glass. It helps me from over applying the resin.
I keep a gallon can with acetone in it and let the roller set in the can while I am glassing.
Helps keep the buildup off the roller. I also use a wire brush to clean the roller before the resin sets up.
I also take the screw out of the end of the rollor after each use and clean the parts in the acetone.
But I really like to set fire to it and burn it completely clean.
I like the way you drilled out the holes and filled them back in with PB. I think I will do mine that way.
Keep up the good work.
Thanks Decker,
