GT1000000
Thread starter- Joined
- Jul 13, 2011
- 4,916
Pick on me all you want, my friend...:smile:
As in the previous "test" I conducted above [ post # 2308], I was able to heat it soft enough to bend without kinking...without sand...then again, this is only 1.5" diameter and made of solid PVC.
I would have to totally agree that packing the sand into the pipe and capping both ends may have done part of the trick, this is after all a 3" inside diameter pipe...
I still think a majority of it has to do with the different layers used to make up this DWV PVC...you can get the outer skin hot enough, but the foam layer between doesn't seem to transmit the same heat to the inner skin...IDK, maybe...:noidea:
Back when, we could heat PVC, rotisserie style, under a long heating element and make it do some wild stuff...
In my time crunched world, I just had to try and make it happen as fast as possible and git-r-dun!...
and like the song says...
It was the heat of the moment...
In the end, lessons learned...
1- Sometimes trying to save some money, costs more in time than its worth...
2- Ends up that by spending a few extra bucks, the various fittings available can usually work just fine...
3- No matter what, though...unless you do all this stuff for a living, its hard to try and figure it out on the fly...
Using the fittings available from the Mfg., and being 3" inside diameter, all the control cables and harnesses will go through the bends just fine...along with a bit of custom engineering...
Oh and thanks for the idea on the heating element to bend PVC, nurseman...but that ain't gonna happen...:shocked:
Anyhow, I appreciate all the input but the final word on this part of the project is that I will be using the fittings available to make the bends necessary on this foam cored 3" pipe...
I will be limiting any PVC bending to smaller diameter stuff, 2" or less...
Happy 2's day...
Happy 2's day...
