MNhunter1
Thread starter- Joined
- May 12, 2014
- 1,141
1982 115hp Mercury inline 6, serial number identifies this motor as prop rated. This motor was picked up as a “parts motor” as it was not running after a rebuild. Apparently had a piston issue, cylinder was honed, piston replaced, and the original owner could never get it to start again. Has good spark and my compression test shows 125-130 psi on all cylinders except for #5, which shows 105 psi.
So low compression in #5, but still over 100 psi. First thought would be possibly stuck ring, but it also could have been a result of improper rebuild/assembly. I wouldn’t expect the lower compression in one cylinder to be a contributor to the no start issue, but I haven’t dug into any of that yet.
Is this motor worth digging into, or do I just leave it as a parts motor as originally intended? Would it still run okay with the lower compression in #5?
