Low Compression After Overhaul
Hooty
Re: Low Compression After Overhaul
Hey, no problem. You and WildeOne kinda ask the same thing. I'm like everybody else, I can't see the engine runnin' with compression that low but ...<br /><br />c/6<br />Hooty
ob
I'm with many of the above posts.Recheck compression using a known good guage.If your readings are still low ,I would suspect a misapplication of the rings(ie end gap).If a few broke on a cylinder or two the readings would not be consistent but rather sporatic.It would be nothing short of a miracle for this engine to run under load in water with 30psi compression across the board.Even a shallow crosshatch IMO would not cause readings that low ,and at worst would delay the seating of the rings as long as the bore is concentric.
ledgefinder
Ensign
Is it possible he's got the wrong pistons in there - loopers with no domes?
Hooty
I think chip51maker figgered what was wrong, but he's not gonna tell. ;) <br /><br />c/6<br />Hooty
CFronzek
Check your compression tester. It should have a valve core with a light weight spring in it. If someone has accidentally installed a core intended for a tire (it is identical except for the spring which is much heavier) the gauge will read low.<br />Charlie
wilde1j
Hooty, I think your right ... the silence is deafening!
OBJ
This suspense is killin' me!!!!!! Chipmaker...WHAT'S UP!!
8up
This is like reading a book with the last chapter torn out!
chip51maker
Good morning,<br /> I appreciate all of your help and suggestions. As far as a time line, I rebuilt this motor last July and have never been really satisfied with its performance. I was discouraged and did not really know what to do. Only recently did a friend suggest that I try an "Online Forum" to get help from others that do this stuff everyday.<br /> Again thank all of You for your help and please accept My apology for not responding in a timely manner.<br /> As for the motor, I have found that the crankcase halves are leaking due to the fact that I did not use the proper "Crankcase Sealant"<br />I believe that the crankcase leaking (I can see 2 places that has blown out) for sure explains the less than desireable performance. All of this time I thought that I had an ignition problem. I have not addressed the compression problem yet but I did put the incorrect valve core in my compression gage. Hopefully the compression is acceptable and just my readings are wrong.<br /> I will keep you posted as things develop. It will be several weeks for sure. <br />Thanks <br />H
wilde1j
Make sure the halves are absolutely clean and wipe the mating surfaces with trichlor or other good degreaser before applying Gel Seal and you should be fine. Glad the gauge was probably wacked.<br />Keep us posted on how you're coming along.
